| basically at the connector to the subharness (on top of the engine) there are 2 wires, 1 white wire (hot), and 1 black wire (ground) on the subharness itself the black wire runs around the white wire (i can only guess as a shield wire) Near the bottom the two wires merge into one and then they go to the sensor itself. make sure the white wire has good continuity to the ECU and make sure the black wire has good continuity to ground.
